Am unable to attach a Surface Go to a WPA3-PSK (SAE) network, any idea?
Cheers.
Edit: Problem not limited to Go but other older Surface devices as well.
May 10, 2024
April 9, 2024
Click here to learn more 💡
Cheers.
Just wondering, have you or anyone personally been able to do so?
Cheers.
·Was this reply helpful?
1. Are you still in S mode?
2. If you ARE in S mode, if you switch out, any difference?
3. the experience definitely depends on what you are connecting to. just because someone can connect to a Netgear AX12 router that is configured for WPA3 with fallback to WPA2, doesn't mean they can connect to a Linksys router.
Not in S mode.
So you have been able to connect a Surface Go to either 1) WPA3 network or 2) WPA3 with WPA2 fallback network
Cheers.
Following the instructions on the page below, by running the command netsh wlan show drivers, WPA3-Personal is not currently supported on the Go, and presumably most other Surface devices as well.
Hopefully Microsoft/Qualcomm/Marvell can release updated driver to enable WPA3-Personal/PSK/SAE support.
Cheers.
https://dokuwiki.alu4u.com/doku.php?id=stellar-wireless-win10-windows-10-wpa3-sae
Thanks. What bothers me is that I don't even see Intel updating their older WiFi products to WPA3. Intel has only added WPA3 to their 9200 series adapters and the AX200/201 series. I hope that this is not a hardware limitation or an unwillingness to work on older hardware.
I DID find statements on the WiFi Alliance page from both Marvell and Qualcomm
I'd love to see a comment from the Surface team (an authoritative response).
OpenWrt (an open source router firmware replacement) just saw a new release last month. It enabled my years old router to operate WPA3-PSK networks. It's a software issue.
Whether the vendors are willing to spend time and effort (i.e. $$$) to update/support the already sold devices is a business decision though.
Am not holding my breath either, but I do wish Microsoft to do better.
Cheers.
